Api event user set domain icon
API Endpoint: api/event/user/set_domain_icon/
Description: Set the Domain icon used in (web) viewers. The image must be in .png Format, must be square, and must be at most 100KB.
0 OPTIONAL (String) Domain Name (optional, leave empty by default)
1 REQUIRED (byte or multiple values in array [a, b, c]) .png file
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/user/set_domain_icon/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "", 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/event/user/set_domain_icon/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "", [ 1, 2, 3 ] ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "", 1 ]'
fetch("https://engine.tygron.com/api/event/user/set_domain_icon/", options)
