Api event user remove user
API Endpoint: api/event/user/remove_user/
Description: Remove a user. Returns whether the user was deleted.
0 REQUIRED (String) Username
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/user/remove_user/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '"Username"'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '"Username"'
fetch("https://engine.tygron.com/api/event/user/remove_user/", options)
