Api event io validate project name
API Endpoint: api/event/io/validate_project_name/
Description: Validate that a given string would be a valid Project file name. Returns an empty string if the Project name is valid and not in use. Otherwise it returns the reason why it is not valid.
0 REQUIRED (String) Project Name
200 String (String)
curl 'https://engine.tygron.com/api/event/io/validate_project_name/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '"Project Name"'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '"Project Name"'
fetch("https://engine.tygron.com/api/event/io/validate_project_name/", options)
