Api event io set project name
API Endpoint: api/event/io/set_project_name/
Description: Change the name of a Project.
0 REQUIRED (String) Name of the Project to rename
1 REQUIRED (String) New name for the Project
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/set_project_name/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Name of the Project to rename", "New name for the Project" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "Name of the Project to rename", "New name for the Project" ]'
fetch("https://engine.tygron.com/api/event/io/set_project_name/", options)
