Api event io set project language
API Endpoint: api/event/io/set_project_language/
Description: Set whether a specific language is available for a Project.
0 REQUIRED (String) Project Name
1 REQUIRED (Enumeration) Project language: NL, EN EN or NL
2 REQUIRED (true, false) Whether the language is available true or false
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/set_project_language/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Project Name", "EN", true ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "Project Name", "EN", true ]'
fetch("https://engine.tygron.com/api/event/io/set_project_language/", options)
