Api event io add project
API Endpoint: api/event/io/add_project/
Description: Create a new Project with a given name and language. Returns the new Project's data.
0 REQUIRED (String) Project Name
1 OPTIONAL (Enumeration) Language (NL, EN)
2 OPTIONAL (true, false) High Detail level (<10m DEM, <5m Grid)
200 ProjectData (ProjectData)
curl 'https://engine.tygron.com/api/event/io/add_project/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '"Project Name"'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '"Project Name"'
fetch("https://engine.tygron.com/api/event/io/add_project/", options)
