Api session query
API Base URL: api/session/query/
GET {query}
API Endpoint: api/session/query/{query}
Parameters:
| Name | Location | Type | Default value |
| query | Path | String | |
| value | Query | String | 0.0 |
| f | Query | Format | JSON |
| validate | Query | boolean | false |
| crs | Query | String | EPSG:3857 |
Examples
SELECT_FLOORSIZE_WHERE_CATEGORY_IS_SHOPPING_AND_MAP_IS_MAQUETTE:
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_SHOPPING_AND_MAP_IS_MAQUETTE?crs=3857&f=JSON&token=API_TOKENPOST query
Content-Type: application/x-www-form-urlencoded
Parameters:
POST query
Content-Type: application/json
Parameters:
Examples
curl 'https://engine.tygron.com/api/session/query/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials> API_TOKEN' -d '"TQL Query 1"'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/query/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials> API_TOKEN' -d '[ "TQL Query 1", "TQL Query 2", "TQL Query 3" ]'JavaScript example POST:
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials> API_TOKEN" },
body: '"TQL Query 1"'
fetch("https://engine.tygron.com/api/session/query/", options)
