Api event share set certificate author
Revision as of 15:18, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/share/set_certificate_author/
Description: Set Certificate of Authorship to validate the originality of the shareable in a Project.
0 REQUIRED (String or multiple values in array ["a", "b", "c"]) Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/")
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Certificate author name
200 Boolean (Content was updated)
curl 'https://devshare.tygron.com/api/event/share/set_certificate_author/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Path 1", "Certificate author name 1" ]'
Curl example multi item POST
curl 'https://devshare.tygron.com/api/event/share/set_certificate_author/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ [ "Path 1", "Path 2", "Path 3" ], [ "Certificate author name 1", "Certificate author name 2", "Certificate author name 3" ] ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "Path 1", "Certificate author name 1" ]'
fetch("https://devshare.tygron.com/api/event/share/set_certificate_author/", options)
