Api event share add url
Revision as of 15:18, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/share/add_url/
Description: Add new Shareable for given path, name and type; returns a unique path with primary extension.
0 REQUIRED (String) Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/")
1 REQUIRED (Enumeration) Type CITYGML, CITYJSON, CSV, DIRECTORY, DOC, DXF, EXCEL, GEOJSON, GEOPACKAGE, GEOTIFF, GIF, IFC, JPEG, MARKDOWN, ONNX, PDF, PNG, SLIDES, SLPK, TXT, VIEWER or ZIP
2 OPTIONAL (String) URL with Content (optional)
200 String (String)
curl 'https://devshare.tygron.com/api/event/share/add_url/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Path", "GEOTIFF" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "Path", "GEOTIFF" ]'
fetch("https://devshare.tygron.com/api/event/share/add_url/", options)
