Api event io set session keep alive
Revision as of 15:17, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/io/set_session_keep_alive/
Description: Enable or disable Keep Alive for a running Session to determine if it persists without connected clients.
0 REQUIRED (Integer number) Session ID
1 REQUIRED (Enumeration) How long the Session must be kept alive LONG, NEVER or SHORT
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/set_session_keep_alive/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ 1, "NEVER" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ 1, "NEVER" ]'
fetch("https://engine.tygron.com/api/event/io/set_session_keep_alive/", options)
