Api event io save project as
API Endpoint: api/event/io/save_project_as/
Description: Save the current state of an EDITOR Session as a new Project. This sets the initial state for future Sessions; the current Session continues using the new Project.
| 0 | REQUIRED | (Integer number) | Session ID | |
| 1 | OPTIONAL | (String) | Domain Name (optional, leave empty by default) | |
| 2 | REQUIRED | (String) | New Project Name | |
| 3 | REQUIRED | (true, false) | Save all data (set to false if you want to use the running Session as a template for a new Project) | true or false |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/event/io/save_project_as/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ 1, "", "New Project Name", true ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '[ 1, "", "New Project Name", true ]'
fetch("https://engine.tygron.com/api/event/io/save_project_as/", options)
