Api event io get startable projects
Revision as of 15:17, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/io/get_startable_projects/
Description: Get all Projects in the Domain which can start a Session.
200 ProjectData[] (ProjectData array)
curl 'https://engine.tygron.com/api/event/io/get_startable_projects/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d ''
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: ''
fetch("https://engine.tygron.com/api/event/io/get_startable_projects/", options)
