Api event io get session keep alive
Revision as of 15:17, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/io/get_session_keep_alive/
Description: Returns whether the Session identified by the Session ID is set to Keep Alive. Value can also be found in Setting KEEP_ALIVE.
0 REQUIRED (Integer number) Session ID
200 KeepAlive (KeepAlive)
curl 'https://engine.tygron.com/api/event/io/get_session_keep_alive/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '1'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '1'
fetch("https://engine.tygron.com/api/event/io/get_session_keep_alive/", options)
