Api event io add project
API Endpoint: api/event/io/add_project/
Description: Create a new Project with a given name and language. Returns the new Project's data.
| 0 | REQUIRED | (String) | Project Name | |
| 1 | OPTIONAL | (Enumeration) | Language (NL, EN) | |
| 2 | OPTIONAL | (true, false) | High Detail level (<10m DEM, <5m Grid) |
| 200 | ProjectData (ProjectData) |
curl 'https://engine.tygron.com/api/event/io/add_project/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '"Project Name"'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '"Project Name"'
fetch("https://engine.tygron.com/api/event/io/add_project/", options)
