Api event share set disclaimer
Revision as of 14:50, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/share/set_disclaimer/ Description: Set disclaimer for given path. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/") | |- | 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Disclaimer text | |} ===Response Codes=== {|class=wikitable !Res...")
0 REQUIRED (String or multiple values in array ["a", "b", "c"]) Path (e.g. "mydir/myname.tiff", note: viewers and directories end with a slash e.g. "mydir/viewer/")
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Disclaimer text
200 Boolean (Content was updated)
curl 'https://devshare.tygron.com/api/event/share/set_disclaimer/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ "Path 1", "Disclaimer text 1" ]'
Curl example multi item POST
curl 'https://devshare.tygron.com/api/event/share/set_disclaimer/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ [ "Path 1", "Path 2", "Path 3" ], [ "Disclaimer text 1", "Disclaimer text 2", "Disclaimer text 3" ] ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '[ "Path 1", "Disclaimer text 1" ]'
fetch("https://devshare.tygron.com/api/event/share/set_disclaimer/", options)
