Api event user set user passwd
Revision as of 14:50, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/user/set_user_passwd/ Description: Change the password for a given user. Returns the user's login key for continued authentication, or null if you are unauthorized to change that user's password. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (String) | Username | |- | 1 | REQUIRED | (String) | Password | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 200 | String (String) |- |...")
0 REQUIRED (String) Username
1 REQUIRED (String) Password
200 String (String)
curl 'https://engine.tygron.com/api/event/user/set_user_passwd/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ "Username", "Password" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '[ "Username", "Password" ]'
fetch("https://engine.tygron.com/api/event/user/set_user_passwd/", options)
