Api event user set user active
Revision as of 14:50, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/user/set_user_active/ Description: Set whether a specified user account is active. Returns whether the user was successfully updated. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | OPTIONAL | (String) | Domain Name (optional, leave empty by default) | |- | 1 | REQUIRED | (String) | Username | |- | 2 | REQUIRED | (true, false) | Whether account should be active | true or false |} ===Response Codes=== {|class=wikitabl...")
0 OPTIONAL (String) Domain Name (optional, leave empty by default)
1 REQUIRED (String) Username
2 REQUIRED (true, false) Whether account should be active true or false
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/user/set_user_active/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ "", "Username", true ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '[ "", "Username", true ]'
fetch("https://engine.tygron.com/api/event/user/set_user_active/", options)
