Api event user remove user
Revision as of 14:50, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/user/remove_user/ Description: Remove a user. Returns whether the user was deleted. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (String) | Username | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 200 | Boolean (Content was updated) |- | 300-600 | Codes Overview |} ===Example POST=== Curl example POST <syntaxhighlight lang="text" copy>curl 'https://engine.tygron.com/api/event/...")
0 REQUIRED (String) Username
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/user/remove_user/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '"Username"'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '"Username"'
fetch("https://engine.tygron.com/api/event/user/remove_user/", options)
