Api event io validate project name
Revision as of 14:49, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/io/validate_project_name/ Description: Validate that a given string would be a valid Project file name. Returns an empty string if the Project name is valid and not in use. Otherwise it returns the reason why it is not valid. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (String) | Project Name | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 200 | String (String) |- | 300-600 |...")
0 REQUIRED (String) Project Name
200 String (String)
curl 'https://engine.tygron.com/api/event/io/validate_project_name/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '"Project Name"'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '"Project Name"'
fetch("https://engine.tygron.com/api/event/io/validate_project_name/", options)
