Api event io set project name
API Endpoint: api/event/io/set_project_name/
Description: Change the name of a Project.
| 0 | REQUIRED | (String) | Name of the Project to rename | |
| 1 | REQUIRED | (String) | New name for the Project |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/event/io/set_project_name/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ "Name of the Project to rename", "New name for the Project" ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
body: '[ "Name of the Project to rename", "New name for the Project" ]'
fetch("https://engine.tygron.com/api/event/io/set_project_name/", options)
