Api event io save project as
Revision as of 14:49, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/io/save_project_as/ Description: Save the current state of an EDITOR Session as a new Project. This sets the initial state for future Sessions; the current Session continues using the new Project. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (Integer number) | Session ID | |- | 1 | OPTIONAL | (String) | Domain Name (optional, leave empty by default) | |- | 2 | REQUIRED | (String) | New Pro...")
0 REQUIRED (Integer number) Session ID
1 OPTIONAL (String) Domain Name (optional, leave empty by default)
2 REQUIRED (String) New Project Name
3 REQUIRED (true, false) Save all data (set to false if you want to use the running Session as a template for a new Project) true or false
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/save_project_as/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ 1, "", "New Project Name", true ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '[ 1, "", "New Project Name", true ]'
fetch("https://engine.tygron.com/api/event/io/save_project_as/", options)
