Api event io get session keep alive
API Endpoint: api/event/io/get_session_keep_alive/
Description: Returns whether the Session identified by the Session ID is set to Keep Alive. Value can also be found in Setting KEEP_ALIVE.
| 0 | REQUIRED | (Integer number) | Session ID |
| 200 | KeepAlive (KeepAlive) |
curl 'https://engine.tygron.com/api/event/io/get_session_keep_alive/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '1'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
body: '1'
fetch("https://engine.tygron.com/api/event/io/get_session_keep_alive/", options)
