Api event io get project saved sessions
Revision as of 14:47, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/io/get_project_saved_sessions/ Description: Get all saved Domain Sessions for a specified Project. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | OPTIONAL | (String) | Domain Name (optional, leave empty by default) | |- | 1 | REQUIRED | (String) | Project Name | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 200 | SaveData[] (SaveData array) |- | 300-600 | Codes Overview |} ===Example...")
0 OPTIONAL (String) Domain Name (optional, leave empty by default)
1 REQUIRED (String) Project Name
200 SaveData[] (SaveData array)
curl 'https://engine.tygron.com/api/event/io/get_project_saved_sessions/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '[ "", "Project Name" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '[ "", "Project Name" ]'
fetch("https://engine.tygron.com/api/event/io/get_project_saved_sessions/", options)
