Api event io add project
Revision as of 14:39, 19 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Endpoint: api/event/io/add_project/ Description: Create a new Project with a given name and language. Returns the new Project's data. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (String) | Project Name | |- | 1 | OPTIONAL | (Enumeration) | Language (NL, EN) | |- | 2 | OPTIONAL | (true, false) | High Detail level (<10m DEM, <5m Grid) | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 200 | Pro...")
0 REQUIRED (String) Project Name
1 OPTIONAL (Enumeration) Language (NL, EN)
2 OPTIONAL (true, false) High Detail level (<10m DEM, <5m Grid)
200 ProjectData (ProjectData)
curl 'https://engine.tygron.com/api/event/io/add_project/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>=' -d '"Project Name"'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>=" },
 body: '"Project Name"'
fetch("https://engine.tygron.com/api/event/io/add_project/", options)
