How to add or remove or duplicate an Indicator
Revision as of 10:00, 18 November 2026 by Server@tygron.com (talk | contribs)
Editor → Current Situation (Ribbon tab) → Indicators (Ribbon bar)
The left panel for Indicators in the editor, filtering indicators of a particular Stakeholder.
Adding an Indicator means making an Indicator available for use in the project. By default, an Indicator is visible to and accessible by all stakeholders. You can make it personal to restrict visibility to a specific Stakeholder. It is important to make sure the Indicators are added to the stakeholders for whom they are applicable. When a shared Indicator is removed, it is automatically removed from all stakeholders. When a stakeholder is removed, no Indicators are removed from the project.
Add
How to add an Indicator to the project:
  1. Select the type of Indicator you wish to add.
  2. If applicable, select the stakeholder to assign the indicator to.
  3. Select "Add".
Remove
How to remove an Indicator from the project:
  1. Select the Indicator you want to remove.
  2. Select "Remove".
Duplicate
How to duplicate an Indicator from the project:
  1. Select the Indicator you want to duplicate.
  2. Select "Duplicate".
