How to manually adjust Indicators in Excel
Revision as of 09:55, 18 November 2026 by Server@tygron.com (talk | contribs)
How to manually adjust Indicators in Excel:
  1. Go to Current Situation -> Indicators, "Add" a new Excel indicator in the bottom left corner.
  2. Click "Select Excel sheet" (middle right) to choose the indicator downloaded from the Public GeoShare.
  3. Import the new Excel sheet.
  4. The indicator should be visible in the top bar.
  5. "Update" platform.
  6. Press "Debug Excel Sheet".
  7. Save the Debugged Excel Sheet with the desired name.
  8. Open this file in Excel.
  9. Adjust the values in the column with the desired values (e.g. targets for each neighborhood) and save the file.
  10. Go back to the Tygron Platform and press "select Excel Sheet" again and "import" or "update" the saved Excel Sheet.
