How to change individual ownership
Revision as of 09:54, 18 November 2026 by Server@tygron.com (talk | contribs)
Editor → Current Situation (Ribbon tab) → Buildings (Ribbon bar)
How to change ownership of individual buildings:
  1. Select Current Situation > Buildings > Show Buildings
  2. Select the building of which ownership needs to be changed from the list of buildings on the left panel, or by directly selecting the building in the 3D Visualization
  3. Select on the right panel, from the properties of the selected building, the desired owner from the drop down menu of field named "Owner"
Editor → Current Situation (Ribbon tab) → Administrative (Ribbon bar) → Show Plots (Dropdown)
How to change ownership of individual plots:
  1. Select Current Situation > Administrative >Show Plots
  2. Select the plot of which ownership needs to be changed from the list of plots on the left panel, or by directly selecting the plot in the 3D Visualization
  3. Select on the right panel, from the properties of the selected plot, the desired owner from the drop down menu of field named "Owner"
