How to add and remove Globals
Revision as of 09:54, 18 November 2026 by Server@tygron.com (talk | contribs)
Editor → Current Situation (Ribbon tab) → Globals (Ribbon bar)
The Left Panel allows you to add, duplicate, and remove globals.
How to add a global:
  1. Select Current Situation in the ribbon bar.
  2. Hover over Globals in the ribbon bar.
  3. Select the option named "Add new Global".
How to duplicate a global:
  2. Select Globals in the ribbon bar.
  3. In the left panel, select the global you wish to duplicate.
  4. In the left panel, select "Duplicate".
How to remove a global:
  3. In the left panel, select the global you wish to remove.
  4. In the left panel, select "Remove".
