How to add and remove measures
Revision as of 09:52, 18 November 2026 by Server@tygron.com (talk | contribs)
Editor → Future Design (Ribbon tab) → Measures (Ribbon bar)
The left panel allows you to select measures.
How to add a new measure:
  1. Select "Future Design" in the ribbon header.
  2. Select "Measures" in the ribbon bar.
  3. Select "Add" in the left panel.
How to duplicate an existing measure:
  3. Select an existing measure you wish to duplicate.
  4. Select "Duplicate" in the left panel.
How to remove an existing measure:
  3. Select the measure you wish to remove.
  4. Select "Remove" in the left panel.
