Api session event editor scenario set event
Revision as of 15:50, 16 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorscenario/set_event/
Description: Replace the Coded Event of a Scenario
0 REQUIRED (SCENARIO Integer ID) Scenario
1 REQUIRED (CodedEvent) Coded Event
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "id" : -1,
 "parameters" : [ ]
JavaScript example POST
 body: '[ 1, { "id" : -1, "parameters" : [ ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/set_event/", options)
