Text Panel
Calculation Model
The $TQL tags in the text content of a Text Panel are calculated and replaced by their resulting values. These tags must always be preceded by a dollar sign ($), followed by either a TQL Select statement, or one of the supported text panel tags. The TQL tags may also end with a dollar sign. TQL statements always require a performed project calculation.
Example: $SELECT_NAME_WHERE_NEIGHBORHOOD_IS_0 and $SELECT_NAME_WHERE_NEIGHBORHOOD_IS_0$ will both be identified and replaced.
Important: $TQL tags used in JavaScript that contain X or Y clauses should be put between brackets.
Web interface
Main article: Web interface
The Web interface can be enriched by adding a Panel to it with HTML, CSS and/or javaScript code. The content of the Panel is directly injected into the Web interface.
Text Template Panel
Main article: Template Panel
Text Panels can also be generated through the use of Template Panels. These behave mostly like normal Text Panels but are not directly accessible to the end-user. Instead, based on a Template Panel, Text Panels can be generated automatically, related to specific data in the Project.
API Endpoints
  • Text Panel text property endpoint:
/api/session/items/panels/ID/text
where ID should be replaced with the Text Panel's Item ID
