Text Panel
Revision as of 15:26, 12 November 2026 by Frank@tygron.nl (talk | contribs)
Calculation Model
The $TQL tags in the text content of a Text Panel are calculated and replaced by their resulting values. These tags must always be preceded by a dollar sign ($), followed by either a TQL Select statement, or one of the supported text panel tags. The TQL tags may also end with a dollar sign. TQL statements always require a performed project calculation.
Example: $SELECT_NAME_WHERE_NEIGHBORHOOD_IS_0 and $SELECT_NAME_WHERE_NEIGHBORHOOD_IS_0$ will both be identified and replaced.
Important: $TQL tags used in JavaScript that contain X or Y clauses should be put between brackets.
API Endpoints
  • Text Panel text property endpoint, where ID should be replaced with the Text Panel's Item ID: /api/session/items/panels/ID/text
  • Text Panel HTML endpoint: Web panel
