Api session event editor setting set timestamp format
API Endpoint: api/session/event/editorsetting/set_timestamp_format/
Description: Set the timestamp Format for Dates and Times, used for displaying Dates and Times
| 0 | REQUIRED | (String) | Date-Time Format |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_timestamp_format/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Date-time format"'JavaScript example POST
body: '"Date-time format"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_timestamp_format/", options)
