Api session items geotiffs
Revision as of 14:56, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/geotiffs/
Edit items with events described at Api session event editor geotiff.
Default Query:
https://engine.tygron.com/api/session/items/geotiffs/?token=API_TOKEN
Example Response:
  "id" : 0,
  "name" : "NL_GHG_kk-nhi",
  "override" : true,
  "uploadDate" : null,
  "uploaderName" : "NHI Data",
  "version" : 1,
  "warnings" : ""
  "id" : 1,
  "name" : "NL_GLG_kk-nhi",
  "override" : false,
  "version" : 2,
  "warnings" : ""
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/geotiffs/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/geotiffs/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/geotiffs/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/geotiffs/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/geotiffs/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/geotiffs/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/geotiffs/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/geotiffs/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/geotiffs/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/geotiffs/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/geotiffs/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/geotiffs/?f=ZIPSMILE&token=API_TOKEN
Api Model DefaultGeoTiff
API Model description of DefaultGeoTiff
Name Type Description
id int
name String
override boolean
uploadDate long
uploaderName String
version int
warnings String
Api Model GeoTiff
API Model description of GeoTiff
id int
name String
uploadDate long
uploaderName String
version int
warnings String
