Api session event participant net cluster set load attribute
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/net_cluster_set_load_attribute/
Description: Stakeholder sets an Attribute to a value, for each Net Load of a Net Cluster
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (NET_CLUSTER Integer ID) Net Cluster
2 REQUIRED (String) Attribute
3 REQUIRED (Floating point number) Value
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Attribute", 56 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Attribute", 97 ]'
JavaScript example POST
 body: '[ 1, 1, "Attribute", 56 ]'
fetch("https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attribute/", options)
