Api session event participant action menu set active
Revision as of 14:55, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/action_menu_set_active/
Description: Set an Action Menu active for a Stakeholder
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (ACTION_MENU Integer ID) Action Menu
2 REQUIRED (true, false) Active true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/action_menu_set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/participant/action_menu_set_active/", options)
