Api session event editor source add catalog
API Endpoint: api/session/event/editorsource/add_catalog/
Description: Add a new Catalog Source, given a Geo Catalog Type, Name and URL
| 0 | REQUIRED | (Enumeration) | Geo Catalog Type | CSW or ESRI |
| 1 | REQUIRED | (String) | Name | |
| 2 | REQUIRED | (String) | URL |
| 200 | Integer (Catalog Source ID) |
curl 'https://engine.tygron.com/api/session/event/editorsource/add_catalog/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "CSW", "Name", "URL" ]'JavaScript example POST
body: '[ "CSW", "Name", "URL" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/add_catalog/", options)
