Api session event editor setting set sun dates
Revision as of 14:54, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorsetting/set_sun_dates/
Description: Set the Dates between which the Sun movement is interpolated in the 3D Visualization
0 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Array of Times in milliseconds since epoch (Milliseconds since 00:00:00 UTC on 1 January 1970)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_sun_dates/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_sun_dates/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_sun_dates/", options)
