Api session event editor setting set currency
Revision as of 14:54, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorsetting/set_currency/
Description: Set which the Currency is displayed in the interface
0 REQUIRED (Enumeration) Number of decimal places POUND_BRITISH, EURO or DOLLAR_US
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_currency/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"DOLLAR_US"'
JavaScript example POST
 body: '"DOLLAR_US"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_currency/", options)
