Api session event editor scenario add
Revision as of 14:54, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorscenario/add/
Description: Add new Scenario
200 Integer (Scenario ID)
curl 'https://engine.tygron.com/api/session/event/editorscenario/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST
 body: ''
fetch("https://engine.tygron.com/api/session/event/editorscenario/add/", options)
