Api session event editor parametric set function
API Endpoint: api/session/event/editorparametric/set_function/
Description: Set a Function of a Function Type for a Parametric Design. Use Function ID -1 to remove it for a Function Type
| 0 | REQUIRED | (PARAMETRIC_DESIGN Integer ID or multiple integer values in array [1, 2, 3]) | Parametric Designs | |
| 1 | REQUIRED | (FunctionType or multiple values in array [a, b, c]) | Function Type | |
| 2 | REQUIRED | (Integer number or multiple integer values in array [1, 2, 3]) | Function ID |
| 200 | Parametric Design ID |
curl 'https://engine.tygron.com/api/session/event/editorparametric/set_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "ROAD", 1 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorparametric/set_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "ROAD", "WATER", "PARKING" ], [ 1, 2, 3 ] ]'JavaScript example POST
body: '[ 1, "ROAD", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorparametric/set_function/", options)
