Api session event editor panel set layout xy
Revision as of 14:54, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/set_layout_xy/
Description: Set the interface position of a Panel
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (Floating point number) X
2 REQUIRED (Floating point number) Y
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_layout_xy/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 42, 92 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_layout_xy/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 81, 72 ]'
JavaScript example POST
 body: '[ 1, 42, 92 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_layout_xy/", options)
