Api session event editor overlay set water mode
API Endpoint: api/session/event/editoroverlay/set_water_mode/
Description: Set the Water Mode of a Water Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | Water Overlay | |
| 1 | REQUIRED | (Enumeration) | Water Mode | ACCURACY, AVERAGE or SPEED |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_water_mode/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SPEED" ]'JavaScript example POST
body: '[ 1, "SPEED" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_water_mode/", options)
