Api session event editor overlay set tensor prequel
API Endpoint: api/session/event/editoroverlay/set_tensor_prequel/
Description: Set the Inference Prequel for an input tensor of an Inference Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | Inference Overlay | |
| 1 | REQUIRED | (Integer number) | Tensor Link ID | |
| 2 | REQUIRED | (String) | Inference Prequel |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_tensor_prequel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Inference Prequel" ]'JavaScript example POST
body: '[ 1, 1, "Inference Prequel" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_tensor_prequel/", options)
