Api session event editor overlay set prequel
API Endpoint: api/session/event/editoroverlay/set_prequel/
Description: Set Prequel Overlay for a Grid Overlay and a Prequel Type supported by the Grid Overlay. Optionally a specific Timeframe is used to obtain Grid values, with the last Timeframe of the Prequel Overlay as defaultOptionally Grid Values are obtain from a previous Iteration, allowing cyclic dependencies between Grid Overlays
| 0 | REQUIRED | (OVERLAY Integer ID) | Grid Overlay | |
| 1 | REQUIRED | (OVERLAY Integer ID) | Prequel Overlay | |
| 2 | REQUIRED | (String) | Prequel Type Name | |
| 3 | OPTIONAL | (Integer number) | Prequel Timeframe ID (optional) | |
| 4 | OPTIONAL | (true, false) | Previous Iteration (optional) |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_prequel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Prequel Type Name" ]'JavaScript example POST
body: '[ 1, 1, "Prequel Type Name" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_prequel/", options)
