Api session event editor overlay set entry value
Revision as of 14:54, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_entry_value/
Description: Set the value of an entry of an Overlay's legend
0 REQUIRED (OVERLAY Integer ID) Overlay
1 REQUIRED (Integer number) Entry ID
2 REQUIRED (Floating point number) Value
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_entry_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 76 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_entry_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 59 ]'
JavaScript example POST
 body: '[ 1, 1, 76 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_entry_value/", options)
