Api session event editor overlay set avg distance
Revision as of 14:54, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_avg_distance/
Description: Set the averaging distance for an Average Overlay
0 REQUIRED (OVERLAY Integer ID) Avg Overlay
1 REQUIRED (Floating point number) Averaging distance
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 37 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 92 ]'
JavaScript example POST
 body: '[ 1, 37 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/", options)
