Api session event editor overlay add difference entry
API Endpoint: api/session/event/editoroverlay/add_difference_entry/
Description: Add an entry to the difference legend an Overlay
| 0 | REQUIRED | (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) | Overlays | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Names | |
| 2 | OPTIONAL | (TColor or multiple values in array [a, b, c]) | Colors | |
| 3 | OPTIONAL | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Values |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add_difference_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Name 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add_difference_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Name 1", "Name 2", "Name 3" ] ]'JavaScript example POST
body: '[ 1, "Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/add_difference_entry/", options)
