Api session event editor netload generate loads
API Endpoint: api/session/event/editornetload/generate_loads/
Description: Generate Net Loads with a provided Net Type, for Addresses of Buildings inside the provided Polygons, for Buildings of the provided Category and Stakeholders and optionally only for Buildings without Net Loads. Addresses are bundled into one Net Load given a bundle threshold. Net Loads are set as Collective given another threshold. Stakeholder owning the Net Load can be mapped from the Building owner to a different one using the mappingIDs
| 0 | REQUIRED | (Enumeration) | Net Type | ELECTRICITY, GAS, HEAT, INTERNET or SEWER |
| 1 | REQUIRED | (MultiPolygon with crs: EPSG:3857) | Region | |
| 2 | REQUIRED | (Category or multiple values in array [a, b, c]) | Building Categories | |
| 3 | REQUIRED | (Integer number) | Bundle Threshold | |
| 4 | REQUIRED | (Integer number) | Collective Threshold | |
| 5 | REQUIRED | (STAKEHOLDER Integer ID or multiple integer values in array [1, 2, 3]) | Stakeholders (Building owners) | |
| 6 | REQUIRED | (STAKEHOLDER Integer ID or multiple integer values in array [1, 2, 3]) | Stakeholders (mapped) | |
| 7 | REQUIRED | (true, false) | Skip Buildings with Net Loads | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/generate_loads/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ "ELECTRICITY", {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "SOCIAL", 1, 1, 1, 1, true ]
'Curl example multi item POST
[ "ELECTRICITY", {
}, [ "SOCIAL", "NORMAL", "LUXE" ], 1, 1, [ 1, 2, 3 ], [ 1, 2, 3 ], true ]
'JavaScript example POST
body: '[ "ELECTRICITY", { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, "SOCIAL", 1, 1, 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/generate_loads/?crs=3857", options)
