Api session event editor netfunction import
Revision as of 14:52, 11 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetfunction/import/
Description: Import Net Functions by providing names, Net Types and Attributes with accompanying values
0 REQUIRED (String or multiple values in array ["a", "b", "c"]) Names
1 REQUIRED (NetType or multiple values in array [a, b, c]) Net Types
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attributes
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Attribute Values
4 REQUIRED (SOURCE Integer ID) Source
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetfunction/import/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Name 1", "ELECTRICITY", "Attribute 1", [ 1.0, 2.0 ], 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetfunction/import/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "Name 1", "Name 2", "Name 3" ], [ "ELECTRICITY", "GAS", "HEAT" ], [ "Attribute 1", "Attribute 2", "Attribute 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], 1 ]'
JavaScript example POST
 body: '[ "Name 1", "ELECTRICITY", "Attribute 1", [ 1.0, 2.0 ], 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetfunction/import/", options)
